Scavenger Posted February 18, 2016 Report Posted February 18, 2016 (edited) My R53 spent most of its daytime life in parking garages shielded from the sun until I moved to NC. Parking Garages aren't so common here. Anyone with a first gen (or even second gen) that has kept there car outside knows the damage the sun can do. In particular, the headlights. Mine had become really yellowed and fogged. I considered replacement and even though I can do the labor myself, which involves swapping the bulbs, washer mechanism and wiring, total cost is still something like $1300.00 Pelican Parts: (Cheapest) Drivers - 63-12-7-198-739-BOE - $652.25 Passengers - 63-12-7-198-740-BOE - $652.25 So, I found a tutorial on how to restore them myself. I think it is a better job than the store-bought resto-kits that can be found in the auto shops. Slightly more expensive, but still far less than $1300!!! Anyhow... so far, I've done my driver's side headlight, so I wanted to post results for all to see. The tutorial I used is found on Youtube - It took me about 2 hours and I think the results are quite impressive! Here's a picture: Edited March 1, 2016 by Scavenger 2006 MCS, SB/S , "B.A." Performance: DINAN "Stage 5" tune, throttle body, boost kit (fuel pump, pulley), & CAI; JCW exhaust sans resonator, brakes, & GP IC; DDM IC diverter; CSF Racing Aluminum Radiator Suspension: DINAN front strut brace; Alta 22mm rear bar; KW V1 coil-overs; H-Sport adjustable rear control arms; CravenSpeed strut underators Interior: CravenSpeed gauge mounts with Cooper S boost and voltage, & shift well cover Wheels: Enkei PF01 17" Audio: Kenwood Excelon KDC-X994 HU; MTX Terminator speakers F&B Alan @ opensource.com
TGGRRR (Ali) Posted February 18, 2016 Report Posted February 18, 2016 BA is bright eyed and cheery. I need to do this for Tigger Tigger 2006 the cabrio and Riversong the 2014 Countryman
1975_mini Posted February 19, 2016 Report Posted February 19, 2016 Very Nice, it is a very simple process I recommend that anyone to do it. Wet sand till the water runs clear, and you have removed the oxidation and any light scratches. Any light abrasive will work (i.e. toothpaste if you want to be really cheap) Looks great!!!:top: 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels
Scavenger Posted March 1, 2016 Author Report Posted March 1, 2016 UPDATE:::: This evening, I got around to finishing my project by completing the passenger side. Here is a pic. I think it looks great! I'm very happy with the results and affordability of this process, and I recommend it to those not wanting to spend over thousand for new parts. 2006 MCS, SB/S , "B.A." Performance: DINAN "Stage 5" tune, throttle body, boost kit (fuel pump, pulley), & CAI; JCW exhaust sans resonator, brakes, & GP IC; DDM IC diverter; CSF Racing Aluminum Radiator Suspension: DINAN front strut brace; Alta 22mm rear bar; KW V1 coil-overs; H-Sport adjustable rear control arms; CravenSpeed strut underators Interior: CravenSpeed gauge mounts with Cooper S boost and voltage, & shift well cover Wheels: Enkei PF01 17" Audio: Kenwood Excelon KDC-X994 HU; MTX Terminator speakers F&B Alan @ opensource.com
Scavenger Posted March 1, 2016 Author Report Posted March 1, 2016 BA is bright eyed and cheery. I need to do this for Tigger You should... or Mark should :laugh: Once the clearcoat has had plenty of time to set and I make any final touch ups, I'll post a full picture that'll better show the results. Very Nice, it is a very simple process I recommend that anyone to do it. Wet sand till the water runs clear, and you have removed the oxidation and any light scratches. Any light abrasive will work (i.e. toothpaste if you want to be really cheap) Looks great!!!:top: Yep, I tried toothpaste first, but the amount of elbow grease you'll need and the final result really just isn't worth the time. I wanted a result that would last a while, I hope several years! This seems to be it, but time will tell. Thanks for the compliments! :top: Now it is time for some :motor: 2006 MCS, SB/S , "B.A." Performance: DINAN "Stage 5" tune, throttle body, boost kit (fuel pump, pulley), & CAI; JCW exhaust sans resonator, brakes, & GP IC; DDM IC diverter; CSF Racing Aluminum Radiator Suspension: DINAN front strut brace; Alta 22mm rear bar; KW V1 coil-overs; H-Sport adjustable rear control arms; CravenSpeed strut underators Interior: CravenSpeed gauge mounts with Cooper S boost and voltage, & shift well cover Wheels: Enkei PF01 17" Audio: Kenwood Excelon KDC-X994 HU; MTX Terminator speakers F&B Alan @ opensource.com
1975_mini Posted March 1, 2016 Report Posted March 1, 2016 Looks great. Did the kit come with a UV sealant to use after wet sanding. 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels
Scavenger Posted March 2, 2016 Author Report Posted March 2, 2016 Looks great. Did the kit come with a UV sealant to use after wet sanding. No, it's not a kit, I bought everything separately, basically following the list in the tutorial. After sanding, I sprayed it with Clear paint. 2006 MCS, SB/S , "B.A." Performance: DINAN "Stage 5" tune, throttle body, boost kit (fuel pump, pulley), & CAI; JCW exhaust sans resonator, brakes, & GP IC; DDM IC diverter; CSF Racing Aluminum Radiator Suspension: DINAN front strut brace; Alta 22mm rear bar; KW V1 coil-overs; H-Sport adjustable rear control arms; CravenSpeed strut underators Interior: CravenSpeed gauge mounts with Cooper S boost and voltage, & shift well cover Wheels: Enkei PF01 17" Audio: Kenwood Excelon KDC-X994 HU; MTX Terminator speakers F&B Alan @ opensource.com
scythefwd Posted November 3, 2016 Report Posted November 3, 2016 Have you had a chance to run the lights and see if your light pattern is still good or is it more diffuse than when it was new? Is the light output vastly improve?
ucf3 Posted November 8, 2016 Report Posted November 8, 2016 (edited) Clear paint? sounds like a sealant must have been applied. BTW, been meaning to ask, has anyone ever tried using plain (non-gel) toothpaste to get the lens clear before? curious how well it works. Edited November 9, 2016 by ucf3 2k10 Mini Cooper S (R56) 6sp, Coilover suspension, K&N Intake, Alta hotside, Stoptech Rotors, 17" white wheels w/ Conti DW, and resonator delete, S42 turbo upgrade, upgraded intercooler, tuned 250whp. 2k9 Lexus RX350 AWD, Classic Metallic, Sirius radio. 2k8 Audi R8, 4.2, Silver Metallic, StaSis Exhaust, MPSS tires, Sirius radio (Totalled) 2k14 Audi R8 5.2 Suzuka Grey, Larini Exhaust, MPSS tires, Sirius, K&N Filters w/ silicoln sleeve and tuned.
Lt. Dan Posted November 9, 2016 Report Posted November 9, 2016 If people want, I can get club members the BG restoration kit at a really good discount.
1975_mini Posted November 10, 2016 Report Posted November 10, 2016 Clear paint? sounds like a sealant must have been applied. BTW, been meaning to ask, has anyone ever tried using plain (non-gel) toothpaste to get the lens clear before? curious how well it works. I have use regular old tooth paste it works for light oxidation, toothpaste is just a mild abrasive compound like any product to you would buy for the headlights. I takes some elbow grease. If they are cloudy, you are better going with a wet sanding with find sand paper. Start at 1000 and work up to 2500, then seal them. Just my opinion 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels
ucf3 Posted November 14, 2016 Report Posted November 14, 2016 Nice, thanks for the tip 1975_mini. 2k10 Mini Cooper S (R56) 6sp, Coilover suspension, K&N Intake, Alta hotside, Stoptech Rotors, 17" white wheels w/ Conti DW, and resonator delete, S42 turbo upgrade, upgraded intercooler, tuned 250whp. 2k9 Lexus RX350 AWD, Classic Metallic, Sirius radio. 2k8 Audi R8, 4.2, Silver Metallic, StaSis Exhaust, MPSS tires, Sirius radio (Totalled) 2k14 Audi R8 5.2 Suzuka Grey, Larini Exhaust, MPSS tires, Sirius, K&N Filters w/ silicoln sleeve and tuned.
ucf3 Posted November 14, 2016 Report Posted November 14, 2016 If people want, I can get club members the BG restoration kit at a really good discount. Love to get some BG restore. Anything to help my oil burning engine. Let me know when you're ready to buy. 2k10 Mini Cooper S (R56) 6sp, Coilover suspension, K&N Intake, Alta hotside, Stoptech Rotors, 17" white wheels w/ Conti DW, and resonator delete, S42 turbo upgrade, upgraded intercooler, tuned 250whp. 2k9 Lexus RX350 AWD, Classic Metallic, Sirius radio. 2k8 Audi R8, 4.2, Silver Metallic, StaSis Exhaust, MPSS tires, Sirius radio (Totalled) 2k14 Audi R8 5.2 Suzuka Grey, Larini Exhaust, MPSS tires, Sirius, K&N Filters w/ silicoln sleeve and tuned.
