Lt. Dan Posted January 13, 2015 Report Posted January 13, 2015 So I just got the call from Curry's about my PCM issues... Believe it or not, they say my Power Steering Pump is grounding out my PCM, causing all the problems. I have begun my search for a replacement, but wanted to ask if anyone has had any good experience locally picking one up...
Cambo Posted January 13, 2015 Report Posted January 13, 2015 Good to hear they're making progress brother. My first instinct would be to see if Way Motor works has one...or ebay. and then replace that sucker yourself!! 2009 MCS - Passenger seat delete--Rear seat delete--Arm rest delete--Cup holder delete--Seat Belt Delete--Cup holder added back because coffee
JAB 67 Posted January 14, 2015 Report Posted January 14, 2015 Is yours not covered by the recall? JAB 67 Fairfax, VA 2004 MCS, PW/B
Lt. Dan Posted January 14, 2015 Author Report Posted January 14, 2015 Unfortunately my R53 is out of the recall by mileage (188k)
1975_mini Posted January 14, 2015 Report Posted January 14, 2015 rockauto has them for $255 after core. You may want to check some of the local pick-a-parts, I have seen some r53 on the yards now that they are ten years old. 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels
Lt. Dan Posted January 14, 2015 Author Report Posted January 14, 2015 I ended up ordering the Dorman reman unit from Rockauto, should be here in a couple days... Let's see if this fixes it!!!
