FAST060 Posted March 31, 2013 Report Posted March 31, 2013 After seeing Mikes post in the Market Place for his Space Saver MINI Spare, I got to thinking about the new "Big Brakes" and my old spare. Does anyone know if the "Big Brakes" will work with the Space Saver. I see a few options floating around the normal MINI community vendors but one specifically says it will not fit and others mentions shuffling a front tire to a blown rear tire and using the spare on the front. :dontknow: When running Non-runflats, away from homeport, I like to have my spare. New MINI means I might need a new option for spare. Input? https://www.instagram.com/smokiendabandit/ 2009 MCS, HzB/B, CWP, PP, "BLUR" MOTORING ID: SOAR143 - MINI Community Service 2013 JCW GP, Thunder Grey, "SMOKIE" MOTORING ID: FAST060 2014 MCS Clubman, Highclass Gray, "THE ADMIRAL"
68wmcs Posted March 31, 2013 Report Posted March 31, 2013 Well once I have my wheels back on, Craig gave me the idea of selling the steelies off my "Xbox" to DCMM. We can test fit them on your car one day and see if it works. 03 BRG MINI S: Sold! 05 PW Scion xB: D2 Coilovers, XXR 531 16x8, Yakima rack, Yakima basket, WINK, Plaid interior, and a whopping 108 HP!
Edge Posted March 31, 2013 Report Posted March 31, 2013 Quitta, You are not going to find any spare wheel that will fit those huge front brakes, short of an extra full size wheel & tire. They are just too big! Instead, what a lot of people do is buy the space saver spare, and if they ever get a flat tire on the front, they jack up the car, remove the rear wheel, move that wheel to the front, and then put the space saver spare on the rear. Whoever you saw post about doing the opposite (moving a front wheel to the back, and putting the space saver on the front), had it backwards. It's just the reality of the situation. The big brakes are worth it though! "Mr. OEM" - 05 JCW (TK, GPIC, SS, GPTA, R56 RSB, StBr, R56 BBK, GPWhls, SV, RS, R56 GSI, IES, StrWhl, GK, HG, LBIT) MCS, HB/HB, Packs: 1, 2, 3 & 4. LSD, Rear FL, LB/PB upholstery (inc. LB SB & HB), HB Int, Anth. HL, PDC, Nav. OEM: DPSM+Aux, SIRIUS, BT, RV Cam, Aux gauges, ILK, Alarm, AK, PFM, DL, SpLnk, CFD, CSL, BIW, R52 diag rods, EuroTL, EuroWT, EPS, EASM. AM: IanCullAUC, Intravee+KCA420i, SchrothR4, MM-STR. License Plate: SUV2BIG MotoringID: CARVE129
minirab Posted March 31, 2013 Report Posted March 31, 2013 I have a MINI space saver for my JCW. For that wheel to fit over the rear brakes you will need a 15mm spacer. I have an extra one I can sell you. You will also need longer lug bolts and I think I have four I don't need. Just a thought.
FAST060 Posted March 31, 2013 Author Report Posted March 31, 2013 68wmcs said: Well once I have my wheels back on, Craig gave me the idea of selling the steelies off my "Xbox" to DCMM. We can test fit them on your car one day and see if it works. Ha ha, "XBox". Edge said: Quitta, You are not going to find any spare wheel that will fit those huge front brakes, short of an extra full size wheel & tire. They are just too big! Instead, what a lot of people do is buy the space saver spare, and if they ever get a flat tire on the front, they jack up the car, remove the rear wheel, move that wheel to the front, and then put the space saver spare on the rear. Whoever you saw post about doing the opposite (moving a front wheel to the back, and putting the space saver on the front), had it backwards. It's just the reality of the situation. The big brakes are worth it though! I think it was me that got it backwards. https://www.instagram.com/smokiendabandit/ 2009 MCS, HzB/B, CWP, PP, "BLUR" MOTORING ID: SOAR143 - MINI Community Service 2013 JCW GP, Thunder Grey, "SMOKIE" MOTORING ID: FAST060 2014 MCS Clubman, Highclass Gray, "THE ADMIRAL"
Stephatron Posted April 2, 2013 Report Posted April 2, 2013 HzBBlur said: Ha ha, "XBox". I think it was me that got it backwards. If your doesn't fit, I can haz?
