1975_mini Posted April 25, 2014 Report Share Posted April 25, 2014 Brandy said Ebony was shifting roughly, so I drove her to work today to find out what she was feeling. All seemed to be fine, but then without warning while driving back up the hill to the house after cross a speed bump, I step on the gas climb to 3k RPMs and BANG!!!, instant lose of drive to the wheels, and the tinging sound of metal bouncing around. I rolled backwards into a parking spot, Park does not work, set the parking break and walked home. Did not climb under due to being in chuck's since its Friday. Once it's stops raining I am going to do some trouble shooting, to see if its catastrophic or just first gear that's gone and I can nurse it the mile to the house. The damn automatic transmission strikes again.:banghead: 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels Link to comment Share on other sites More sharing options...
Poison Ivy Posted April 25, 2014 Report Share Posted April 25, 2014 Sorry to hear that Corey and Brandy. I hope it all works out. P.S. "Chucks = 'Charlie's' uniform worn by Marines every Friday. Link to comment Share on other sites More sharing options...
1975_mini Posted April 25, 2014 Author Report Share Posted April 25, 2014 Thanks for clarifying Catalina, looking at what I wrote most probably thought I didn't want to get my chuck taylors dirty P.S. "Chucks = 'Charlie's' uniform worn by Marines every Friday. 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels Link to comment Share on other sites More sharing options...
TGGRRR (Ali) Posted April 26, 2014 Report Share Posted April 26, 2014 I'm sorry about Ebony, I hope she's back up and running quickly, Keep us posted Tigger 2006 the cabrio and Riversong the 2014 Countryman Link to comment Share on other sites More sharing options...
Stephatron Posted April 26, 2014 Report Share Posted April 26, 2014 I caught the Chuck Taylor's reference! I always called them Chucks! ANNNNNNNNNNND that's awful. I'm really sad to hear shes's been having odd problems like that. the R55/56 transmission isn't meant to do stuff like that. It's actually supposed to be more reliable than the CVT. Good luck guys Link to comment Share on other sites More sharing options...
1975_mini Posted April 28, 2014 Author Report Share Posted April 28, 2014 Well Ebony is safety in the garage, but daughter birthday didn't leave it to do a detailed inspection. What I have been able to do in a quick diagnous: -engine idles fine in park or neutral. -car free rolls in park. -if put in drive grumbling (technical term) sound from transmission Possible likely casues: -broken input shaft (pinion and drive transfer gear on this tran) -ring gear -broken axel The shift linkage with the engine off moves freely through the gears, and if it was transmission was the issue park would likely still work. Hopefully I will be able to get her jacked up and do some crawling around underneath this evening or tomorrow and have a clearer picture. Update to follow soon. 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels Link to comment Share on other sites More sharing options...
cmcveay Posted May 5, 2014 Report Share Posted May 5, 2014 Yep, I'd be leaning towards a sheared output shaft for the tranny or a sheared pinion with those symptoms. I'll cross my fingers for a pinion gear as it's the less expensive alternative. Tell Brandy to stop doing those "J" turns, it's hard on the car! 2014 Jeep Wrangler Unlimited Rubicon "Homer" 2012 MB/CR JCW R55 "Merlin" Sold 2009 LB/LB R56 "Archie" Sold Link to comment Share on other sites More sharing options...
1975_mini Posted August 8, 2014 Author Report Share Posted August 8, 2014 Well, it was the pinion that went, and chewed up the splines on one of the axle in the process. Mini considers this all an enclosed system :banghead:, so ebony is getting a whole new transmission and axle. She should be back on the road Tuesday or Wednesday:rock: 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels Link to comment Share on other sites More sharing options...
Stephatron Posted August 10, 2014 Report Share Posted August 10, 2014 Wait. It JUST went out??? You were having issues in May. What the crap. Link to comment Share on other sites More sharing options...
1975_mini Posted August 14, 2014 Author Report Share Posted August 14, 2014 Wait. It JUST went out??? You were having issues in May. What the crap. That lead to this full failure. Fun fun, came to pick her up today and the new transmission had a bad pump bearing. So now another week to have another one shipping in. Hopefully third times the charm. Ebony is being a real B@&$/!!! 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels Link to comment Share on other sites More sharing options...
