Brian0758
Looking to upgrade brake rotors
I am going to replace my brake pads and want to upgrade my rotors. Any thoughts on what type and the best place to buy them?
Thanks in advance, Brian :top:
PS I would love to upgrade to big brake kits but due to limited funds not ready for the step :frown:
2012 Jeep Rubicon
OEM at Morristown MINI or use DCMM discount at some of the local dealers.
Or...... Brembo replacement rotors :biggrin:
I used it with my Acura a while back, looks good, works great and a reasonable price. :biggrin:
I installed the M7 drilled & slotted rotors with Mintex red pads 2 years ago on my R53. Complete replacement for OEM. I was able to get 50k miles on the front rotors before I replaced them last month. I have OEM in the front, still have the M7 drilled/slotted in back. I just upgraded to SS brake lines with racing brake fluid a month.
Starbuck - 2006 MCS: JCW Engine and Suspension, Alta: 19mm Rear Anti-Sway Bar, Rear Control Arms (top & bottom), Rear End-Links, Alta intake hose, Alta Intercooler Diverter v2
Helix:Rear Seat Delete
M7: Front Strut Bar, 2% Crank Pulley
MiniMadness: JCW Air Filter & Polyurethane rear strut bushings.
Brian, the Hawk HPS pads work really well (I put a full set on Lona's Z) and they are very low dust as well.
Thanks for the info. I have a set of Mintex Red that I bought awhile ago and they are also suppose to be high performance/low dust. I need to replace my OEM and am planning on new rotors. I read the Power Slot are an excellent upgrade but not too expensive.
2012 Jeep Rubicon
Do power slot cyros. Well worth the money, I couldn't warp them with mulitple 150+ stops or with line lock.
Finally decided and got the Power Slot rotors but due to my limited budget could not upgrade to the cyro treated.:frown: Now I need to run over to MachV's to pickup some braided brake lines, ATE brake fluid and the brake caliper paint kit. :top:
2012 Jeep Rubicon
Brembo blanks are the best way to go outside of standard oem rotors. Are you planning on any severe track duty? If not, cross-drilled and slotted rotors are only good for appearance purposes.
