scotty Posted March 2, 2025 Report Posted March 2, 2025 So I was hoping someone might have some insight on this new issue. I just recently did the downstream oxygen sensor and it was spent for sure, put in the ntk as it said that is OEM. So the day after this being done she ran great. Then this morning I start the car up and heard a noise in the rear almost like something was loose then I got a light pop up which is a half lite up motor, looked it up and it said engine power reduced or something like that. Anyone ever have this or any ideas as to what it might be I would appreciate it. Note: no check engine light came on and on the return home that light went off
1975_mini Posted March 6, 2025 Report Posted March 6, 2025 On 3/2/2025 at 5:14 PM, scotty said: So I was hoping someone might have some insight on this new issue. I just recently did the downstream oxygen sensor and it was spent for sure, put in the ntk as it said that is OEM. So the day after this being done she ran great. Then this morning I start the car up and heard a noise in the rear almost like something was loose then I got a light pop up which is a half lite up motor, looked it up and it said engine power reduced or something like that. Anyone ever have this or any ideas as to what it might be I would appreciate it. Note: no check engine light came on and on the return home that light went off Unfortunately that is the default light that displays for anything feeding the ECU values outside the acceptable range. You really need to pull the codes to get a better understanding of the issue. When abouts are you located? 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels
scotty Posted March 6, 2025 Author Report Posted March 6, 2025 That is what I have learned and she is currently in having it looked at. That light has gone away but now I was left with misfire codes po301 po304 so all I can do is wait now and see what they say. Thank you Corey
1975_mini Posted March 6, 2025 Report Posted March 6, 2025 Good news that is cylinder 1 and 4, so not adjacent cylinder that could be a cracked cylinder wall or head gasket. Could be a few things with that: could be it you just replaced the o2 sensor it could have been ready incorrect for a while and created a rich condition resulting in fowled plugs. A common issue on gen2's is coking on the backside of the valves, of time this buildup will effect the seating of the valves resulting in misfires. Luckily that is easily corrected with a walnut blasting of the valves. usually around $350 or so. Keep us in the loop on what they say 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels
scotty Posted March 7, 2025 Author Report Posted March 7, 2025 I have really starting to think that myself to be honest, with 81,000 miles on the clock I am fairly certain there is a good amount of carbon buildup on those valves. Now the plugs were just replaced about 200 miles ago or so and I used NTK plugs, coil pack was done 11,000 miles ago and installed Delphi coils. I have also heard the knock sensor can cause a lot of issues also if it is indeed bad. Thank you for all your help
scotty Posted March 12, 2025 Author Report Posted March 12, 2025 So as of right now it is looking like the high pressure fuel pump we are getting low readings from the fuel rail on the high pressure side going to check and see if there is a leaking fuel injector but because it's a misfire in a single cylinder it is not likely. I am going to do my best to make the run on Saturday but chances are that might not be possible.
1975_mini Posted March 12, 2025 Report Posted March 12, 2025 9 hours ago, scotty said: So as of right now it is looking like the high pressure fuel pump we are getting low readings from the fuel rail on the high pressure side going to check and see if there is a leaking fuel injector but because it's a misfire in a single cylinder it is not likely. I am going to do my best to make the run on Saturday but chances are that might not be possible. HPFP is a common fail item on Gen2, very good chance that is the issue. 1 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels
scotty Posted March 21, 2025 Author Report Posted March 21, 2025 So it did turn out to be the high pressure fuel pump. Got everything taken care of and she is running great now. Still have to do a carbon cleaning on the valves but that will be next after my wallet recovers from this last one lol. Look forward to the next run. Thank you for all your advice 1
STXMINI Posted March 25, 2025 Report Posted March 25, 2025 On 3/21/2025 at 6:12 PM, scotty said: So it did turn out to be the high pressure fuel pump. Got everything taken care of and she is running great now. Still have to do a carbon cleaning on the valves but that will be next after my wallet recovers from this last one lol. Look forward to the next run. Thank you for all your advice Glad you were able to get it sorted, and are back on the road again! 1
