Scavenger Posted April 22, 2021 Report Posted April 22, 2021 (edited) So, this year I've done a lot of work on B.A. to get him back in good condition. After 15 years and 130K miles, a MINI is going to need some work. I wanted to capture it all here. Maybe this information will be helpful to others. Particular first gen owners. After ignition, I replaced the by-pass valve (MINI officially refers to it as "shut-off" valve) and thoroughly cleaned the throttle body. I also replaced the throttle body gasket. I have misplaced some of the pictures, but will update this post if I can find them. For now, here are some pictures of the cleaned up throttle body. After getting the Bypass-valve and Throttle-body back on, I replaced the left and right boots for the Intercooler. They are rubber and had gotten very hard and deformed from the clamps. Equipment List: OEM MINI Shut-off Valve - more generally referred to as by-pass valve. Throttle Body Gasket OEM Intercooler Couplers Right & Left - more generally referred to as boots. Edited April 23, 2021 by Scavenger Add equipment list 3 2006 MCS, SB/S , "B.A." Performance: DINAN "Stage 5" tune, throttle body, boost kit (fuel pump, pulley), & CAI; JCW exhaust sans resonator, brakes, & GP IC; DDM IC diverter; CSF Racing Aluminum Radiator Suspension: DINAN front strut brace; Alta 22mm rear bar; KW V1 coil-overs; H-Sport adjustable rear control arms; CravenSpeed strut underators Interior: CravenSpeed gauge mounts with Cooper S boost and voltage, & shift well cover Wheels: Enkei PF01 17" Audio: Kenwood Excelon KDC-X994 HU; MTX Terminator speakers F&B Alan @ opensource.com
TGGRRR (Ali) Posted April 22, 2021 Report Posted April 22, 2021 On 4/22/2021 at 5:42 PM, Scavenger said: So, this year I've done a lot of work on B.A. to get him back in good condition. After 15 years and 130K miles, a MINI is going to need some work. I wanted to capture it all here. Maybe this information will be helpful to others. Particular first gen owners. After ignition, I replaced the by-pass valve (MINI officially refers to it as "shut-off" valve) and thoroughly cleaned the throttle body. I also replaced the throttle body gasket. I have misplaced some of the pictures, but will update this post if I can find them. For now, here are some pictures of the cleaned up throttle body. Expand I love seeing a loved MINI 2 Tigger 2006 the cabrio and Riversong the 2014 Countryman
1975_mini Posted April 26, 2021 Report Posted April 26, 2021 Looking good 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels
Scavenger Posted April 28, 2021 Author Report Posted April 28, 2021 (edited) On 4/26/2021 at 11:05 AM, 1975_mini said: Looking good Expand Thanks! Edited April 28, 2021 by Scavenger 2006 MCS, SB/S , "B.A." Performance: DINAN "Stage 5" tune, throttle body, boost kit (fuel pump, pulley), & CAI; JCW exhaust sans resonator, brakes, & GP IC; DDM IC diverter; CSF Racing Aluminum Radiator Suspension: DINAN front strut brace; Alta 22mm rear bar; KW V1 coil-overs; H-Sport adjustable rear control arms; CravenSpeed strut underators Interior: CravenSpeed gauge mounts with Cooper S boost and voltage, & shift well cover Wheels: Enkei PF01 17" Audio: Kenwood Excelon KDC-X994 HU; MTX Terminator speakers F&B Alan @ opensource.com
