Scavenger Posted April 22, 2021 Report Posted April 22, 2021 (edited) So, this year I've done a lot of work on B.A. to get him back in good condition. After 15 years and 130K miles, a MINI is going to need some work. I wanted to capture it all here. Maybe this information will be helpful to others. Particular first gen owners. I got started in February, and the first job was to refresh the ignition system. So, I replaced the ignition coil, spark plugs, and spark plug wires. If you have the stock intercooler, then this isn't too difficult, however, if you have a larger aftermarket intercooler, or the JCW GP, like I have, then it needs to be removed since it blocks access to the spark plugs. Once the Intercooler is out of the way, old stuff can be removed. I ordered a new 'OEM' coil from Way Motor Works. The unit I received is made by BERU and is one of the OEM suppliers. You can see that there was quite a lot of corrosion on the contact posts. This is a good time to clean up all the surfaces and hardware. Then install the new parts. New wires are blue! After getting it all installed, a quick test drive felt good. Don't expect a massive difference, but there did seem to be a little smoother feel and acceleration. Equipment List: Way Motor Works Ignition Package - Includes Wires, Plugs & Coil Edited April 23, 2021 by Scavenger Add equipment list 1 2006 MCS, SB/S , "B.A." Performance: DINAN "Stage 5" tune, throttle body, boost kit (fuel pump, pulley), & CAI; JCW exhaust sans resonator, brakes, & GP IC; DDM IC diverter; CSF Racing Aluminum Radiator Suspension: DINAN front strut brace; Alta 22mm rear bar; KW V1 coil-overs; H-Sport adjustable rear control arms; CravenSpeed strut underators Interior: CravenSpeed gauge mounts with Cooper S boost and voltage, & shift well cover Wheels: Enkei PF01 17" Audio: Kenwood Excelon KDC-X994 HU; MTX Terminator speakers F&B Alan @ opensource.com
1975_mini Posted April 26, 2021 Report Posted April 26, 2021 Nice job 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels
Scavenger Posted April 28, 2021 Author Report Posted April 28, 2021 On 4/26/2021 at 7:04 AM, 1975_mini said: Nice job Thanks! 2006 MCS, SB/S , "B.A." Performance: DINAN "Stage 5" tune, throttle body, boost kit (fuel pump, pulley), & CAI; JCW exhaust sans resonator, brakes, & GP IC; DDM IC diverter; CSF Racing Aluminum Radiator Suspension: DINAN front strut brace; Alta 22mm rear bar; KW V1 coil-overs; H-Sport adjustable rear control arms; CravenSpeed strut underators Interior: CravenSpeed gauge mounts with Cooper S boost and voltage, & shift well cover Wheels: Enkei PF01 17" Audio: Kenwood Excelon KDC-X994 HU; MTX Terminator speakers F&B Alan @ opensource.com
