Mother nature Posted April 25, 2020 Report Posted April 25, 2020 I have been trying to see if my intermittent heat inside of car issues can be solved cheap and easily. I replaced the thermostat, no luck. When it does work, it is mainly on the drivers side vents. Any help is greatly appreciated!! Peace and kindness always, Carolyn K Davis
TGGRRR (Ali) Posted April 25, 2020 Report Posted April 25, 2020 1 hour ago, Mother nature said: I have been trying to see if my intermittent heat inside of car issues can be solved cheap and easily. I replaced the thermostat, no luck. When it does work, it is mainly on the drivers side vents. Any help is greatly appreciated!! Peace and kindness always, Carolyn K Davis Which year MINI do you have? Tigger 2006 the cabrio and Riversong the 2014 Countryman
Mother nature Posted April 26, 2020 Author Report Posted April 26, 2020 6 hours ago, TGGRRR (Ali) said: Which year MINI do you have? 2003
1975_mini Posted April 28, 2020 Report Posted April 28, 2020 Just some guesses. Have you checked your cabin filter critter can nest and leaves can make their way there and restrict air flow. Less air means little to no heat. Is your coolant level good, low coolant would hamper heat transfer. if those are all good then likely the heating core. Does it smell sweet when the heat is on. May just be clogged from age and you can flush it out. 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels
