To everyone running a 15% pulley. How often have you been replacing
your belt. I have doing it once a year, but have been wondering if that
is more than I need to. Thanks!
Just curious - are you running the stock belt? If so, perhaps consider putting in a JCW belt instead... as I believe it is a bit shorter to accommodate the JCW pulley, which is not quite as small as the 15%, but at least the JCW belt would be a closer match than the stock belt!
