jcooper Posted April 29, 2013 Report Posted April 29, 2013 Does anyone know if any of the M7 intakes will fit on a 2011 MCS? Thanks!
minime331 Posted April 29, 2013 Report Posted April 29, 2013 If its in the 2nd gen section then it should. STella- 14' Focus ST Roush CAI, Cobb access port stage1 tune, custom Ptuning 3" exhuast, Levels FMIC, Turbosmart BOV, rally armor mud flaps, more to come.
FAST060 Posted April 29, 2013 Report Posted April 29, 2013 If its in the 2nd gen section then it should. +1 Seen a few M7 Intakes at previous Dragons. R56 should be an option. https://www.instagram.com/smokiendabandit/ 2009 MCS, HzB/B, CWP, PP, "BLUR" MOTORING ID: SOAR143 - MINI Community Service 2013 JCW GP, Thunder Grey, "SMOKIE" MOTORING ID: FAST060 2014 MCS Clubman, Highclass Gray, "THE ADMIRAL"
1975_mini Posted May 2, 2013 Report Posted May 2, 2013 i have one in the garage that i can let you use to test fit, but there is no way to test fit with out pulling out the entire factory air box. I agree with everyone else as long as it is the same air box it should fit. it is definitely a tight fit and takes up all the space under the hood. If you have added a strut bar you will likely run into fit issues. I am down is fredericksburg so likely a bit out of the way. 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels
jcooper Posted May 3, 2013 Author Report Posted May 3, 2013 i have one in the garage that i can let you use to test fit, but there is no way to test fit with out pulling out the entire factory air box. I agree with everyone else as long as it is the same air box it should fit. it is definitely a tight fit and takes up all the space under the hood. If you have added a strut bar you will likely run into fit issues. I am down is fredericksburg so likely a bit out of the way. No strut bar currently. Thanks! I'm sure Mach V will be able to determine if it will fit. I'll probably end up having it installed there. Does anyone know where I can find a good lightly used M7 ASG-R for sale?
jcooper Posted May 7, 2013 Author Report Posted May 7, 2013 Also currently have the R90 - 17" CROSS SPOKE COMPOSITE WHEELS on Oliver ( some days I like the way the look other days I don't) I was wondering if anyone was looking to trade wheels or if anyone knew of someone getting rid of a nice looking set? Thanks!
minime331 Posted May 7, 2013 Report Posted May 7, 2013 i love the r90's STella- 14' Focus ST Roush CAI, Cobb access port stage1 tune, custom Ptuning 3" exhuast, Levels FMIC, Turbosmart BOV, rally armor mud flaps, more to come.
