RDG_RCR
FS: Optima Red top battery
I bought this Red Top a little less than a year ago. Never has been drained, 100% start up! Usually these go for $150 + I am looking for just $50. I'm just trying to offset the cost of a smaller battery for relocation. Here are the specs:
UPC: 811405000911
Group 75/35
720 CCA
910 CA
90 Minutes Reserve
Dimensions: 9-5/16" L x 6-13/16" W x 7-5/8" H
Detailed Description
Voltage: 12vCold Cranking Amps @ 0F: 720
Cranking Amps @ 32F: 910
Reserve Capacity: 90
Capacity (C/20 Rate): 44
Internal Resistance (Ohms): 0.003
Length: 9 5/16"
Width: 6 13/16"
Height: 7 5/8"
Minimum Weight (Lbs): 33.1
Terminal Type: Dual SAE & GM
BCI Group: 75/35
Edited by RDG_RCR
new info
CCA: 800 amps
MCA: 1000 amps
Voltage: 12.8V
Resistance: 0.0030 ohms
Capacity: 50 Ah (C/20)
Reserve Capacity: 100 minutes
What specific model is it? The Optima Red Top that can be retrofitted to MINIs is the 34R. That's the one I have (the R stands for reverse polarity - the + and - are on the opposite sides of the usual).
Note: Above info only validated to be accurate for R53s! :)
Thanks for the heads up, I will check and update when I get home.
EDIT: the model number says RED75/35, not sure it will work in any minis :(
Edited by RDG_RCR
