HasAnMTBProblem Posted February 24, 2017 Report Posted February 24, 2017 Curious what the stock boost is on R60 Countryman S. Can't find that anywhere. Anyone know? "Big Pig" - KW V3 Coilovers - Hotchkis rear control arms - Milltek cat back exhaust with black MBRP tips - Flat black vinyl wrapped head/tail light rights - ECS Black Line Tail Lights - Outmotoring Smoked Side Markers - Outmotoring Smoked Scuttle Turn Signals - Joey Mod Head lights - Outmotoring LED Driving Lights - Enkei T6S 18x8 et42 Wheels - Continental ExtremeContact Sport 235/40R18
1975_mini Posted February 25, 2017 Report Posted February 25, 2017 holds at around 11ish with over boost up to 13ish. It is controlled by the ECU so it is not a good idea to play with the wastgate to increase boost, should only be changed via a tune. JCW are holding 20ish with over boost pushing 24. I included a graph from a tune sight that has the OEM boost map along with the map after their tune. Curious what the stock boost is on R60 Countryman S. Can't find that anywhere. Anyone know? 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels
