RDG_RCR Posted March 1, 2016 Report Posted March 1, 2016 Turns out these will fit a MINI (LT Dan runs a similar set up). I have a set of 15x8 +25 wheels with 225/45/15 tires that I can ran on my Exige last year. Tires are Maxxis RC-1 R comps. The wheels only weight 13lbs each. $600 OBO https://www.flickr.com/photos/137310277@N03/with/24090910575/
kickn_wing Posted March 1, 2016 Report Posted March 1, 2016 side note...these will only fit a first gen, second gen brakes are to big HOONIGAN Manic stage 2+, H&R springs, H-Sport 19mm sway bar, K&N intake, Forge Bov, Miltek downpipe, Mini Challenge Exhaust, Alta hotside pipe, Noname Intercooler, Cravenspeed short shifter, Sneed4speed Billyclub, Sneed4speed Aero Package, Sneed4speed ETR, Sneed4speed track rotors, Carbontech AX6 brake pads
Edge Posted March 1, 2016 Report Posted March 1, 2016 kickn_wing said: side note...these will only fit a first gen, second gen brakes are to bigTrue... but they won't fit 1st Gen JCW brakes either (which are the same size as stock 2nd Gen Cooper S brakes). They might fit the stock brakes on 2nd Gen Coopers (non-S), which are only a fraction bigger than the stock 1st Gen Cooper & Cooper S brakes. 15" wheels are small! ...but also light! "Mr. OEM" - 05 JCW (TK, GPIC, SS, GPTA, R56 RSB, StBr, R56 BBK, GPWhls, SV, RS, R56 GSI, IES, StrWhl, GK, HG, LBIT) MCS, HB/HB, Packs: 1, 2, 3 & 4. LSD, Rear FL, LB/PB upholstery (inc. LB SB & HB), HB Int, Anth. HL, PDC, Nav. OEM: DPSM+Aux, SIRIUS, BT, RV Cam, Aux gauges, ILK, Alarm, AK, PFM, DL, SpLnk, CFD, CSL, BIW, R52 diag rods, EuroTL, EuroWT, EPS, EASM. AM: IanCullAUC, Intravee+KCA420i, SchrothR4, MM-STR. License Plate: SUV2BIG MotoringID: CARVE129
