Rob Mc Posted November 12 Report Posted November 12 Need help finding upper right and lower center mounts for engine and trans mount. Currently use polyurethane mounts from Torque Solutions. OEM were too soft and the engine felt like it was having a heart attack with my stage 2+ tune (inc ecu flash, water meth, downpipe delete, borla exhaust, brisk plugs, wagner intercooler) The polyurethane are too hard - engine is fine but all the vibration goes into the cabin and it is a squeek and rattle fest. Freddy at GT Peace is my go to shop. They found Vibra-Technics Lower Engine Mount G2 for the lower but nothing so far for the upper right. Key take away - trying to reduce interior vibration. Suggestions please. best, Rob
1975_mini Posted November 17 Report Posted November 17 You could use an oem trans mount with the powerflex poly insert that adds more stiffness. Also the yellow poly from powerflex for the engine are not to agressive 1975 Mini 1000, 998cc A+ w/ K&N air filter, 10" Mamba wheels
Rob Mc Posted November 18 Author Report Posted November 18 Ordered Vibra-Technics Lower Engine Mount G2 for the lower but your suggestion might help for upper Powerflex site is down but I think I can find them. Thanks
Rob Mc Posted November 21 Author Report Posted November 21 UPDATE - Vibra Techs and the OHLINs coil overs (vs BC Racing that were on there) did the trick. Thanks to Freddy at GT Peace I am back to loving the drive... Rob 3
