etherpool
New HU w/no radio reception. Help!!!
After the usual HK amp failure I decided to go aftermarket and replace the HU. I've rewired the speakers and everything sounds great. Problem is I have virtually no radio reception. I only get two or three FM stations and no AM at all. Car is an 04 R53 with Nav. I did use the FM antenna converter so that I didn't have to cut any wires. There were several wires on the OEM HU that went unused in the new install. Were these antenna power? Any help would be appreciated!
I had the same issue when I swapped radios. Turned out the antenna to adapter connection came loose when I slid the radio into the dash. Wrapping the connection with electrical tape stabilized it enough that its been solid since. Good luck!
Man I wish that was my issue. I checked it before I slid it in the dash and it didn't work. I think it has something to do with the unused wires that came off of the OEM radio harness but I can't find out what they are. GRRR.
