limoman
Antifreeze leak
my baby(SprCupr):idea: is leaking antifreeze from the right front small puddle cant seem to see where it coming from can any one help me?
Thank you in advance
Chuck
Any funky smells in the car? if not x out the heater core. what year coop?
2010 MCS Laurel edition RMW Tune ;-), ALTA FMIC, Invidia Q300 Exhaust, NM Eng. CAI, NM Discharge pipe, NM Charge pipe, NM Strut brace, Open hood scoop, Stri Boost gauge, Craven Speed shiftwell(black), BSH CC, and many more goodies!.
It does not smell in car. coming from the front of engine on the out side my car is a 06 s with:motor: 14,000 miles on it. called mini service .they told me could be the thermostate housing they are known for leaking recomened changing houseing thermostate and casket anyone know h0w hard this is to do
Thank You
Chuck Rossi
Edited by limoman
If you find the leak in the morning after the car has been sitting all night
then it is the thermostat leaking. There is a white plastic gasket that
gets deformed. When the motor is hot it seals perfectly but at night
when the motor cools down it will leak. My 2006 R53 needed replaced
last year. It took the mechanic about 45 min. to replace.
thanks to everyone for all there help hope to have fixed next week.. so My mini can get a good cleaning for saturday.:congrats:
Chuck Rossi
Edited by limoman
I had the same problem over the summer and it turned out to be the coolant expansion tank. It turned out to be about a $50.00 replacement from Outmotoring. Before changing, my engine overheating indicator would light up if it it idled too long. Luckily the replacement worked and it was a fairly affordable DIY fix.
